x64
Epson Stylus R2400 2100 & more
I have the CR30-ti3-Dispensary ready for you on GitHub, make sure to read the readme carefully but using it is pretty straightforward. The default colorprof configuration is set to the preference you shared yesterday. Let me know your results/feedback and star my project on GitHub if you are satisfied.
many thanks for all the work @x64 : I wil give it a try with another type of paper of which I already have profile made for a side by side comparison to see if the CR30 colorimeter is a feasible alternative for a poor man's printer profiling solution costing only about € 70.-. For this I have do some test to compare thos profile side by side in prints.
  • Like
Reactions: x64
x64
The main concern I have is that the presets primarily assume an A-type (tungsten) illuminant for most devices (per ti3 spec: "All instruments except the Spectrocam are assumed to have an 'A' type illuminant"). None of the stock entries explicitly use an LED illuminant, making me think it is unsupported.
But given how close the icc created with the CSV measurements is to the i1Pro1 icc, and we feed the spectral data to omit the SPD model, I think it is feasable.
The i1Pro3 and the SpyderPrint4 use LED illuminant AFAIK.
x64
I re-initiated the github repo because there was a fatal flaw in the configuration (wrong file names). Now you can verify the functionality immediately after downloading by simply running build_profile.py and generating the example ti3 and icc. Nothing else changed, so you can keep using the build you downloaded earlier. Just thought I'd mention it because I versioned back to 0.1.0, for future updates you can follow the versioning.
