- Apr 19, 2007
- USA
- Canon MB5120, Pencil
I think you mean "271 carts" as the OP is in North America.they may not have everything you want for the 571 carts
Also the option of refilling by dripping ink via the ink outlet port into this cartridge. I would recommend neither approach for this cartridge.There is also another option to use for refilling and it’s called a CISS system
Once the OEM cartridge is prepared for top refill, a one time job, then the procedure for refilling is the same as the aftermarket cartridge every time you refill.Here is a video on how to refill the compatible carts and the second is on refilling the OEM carts, you can see the are worlds apart and require a total different approach altogether.
