- Thread starter
- #51
- May 29, 2007
- Ghent, Belgium
- SC-900 ET-8550 WF-7840 TS705
I tried to find the "testprofile v2.csv" in the profile_config.ini but could not find it to remove the wrong file name. I will give it a try tomorrow. Meanwhile you might want to have a look at my files above and see if you can generate the profile and compare it to the one generated with the i1Pro1. The 3D model should be different and larger than the previous one (which was made with pigment ink and on matte paper, so a significantly smaller gamut than this new one on glossy cast paper). You might upload your results already so I can have a look at tomorrow.
