Dubak
 - Dec 26, 2020
 - Canon Pixma MP540
Dear all, I was given a printer - Canon MP540, which works mostly correctly with one exception, the pigment black (PGBK) doesn't produce any output. Printer doesn't print any error messages, ink level for all cartridges is reported correctly, other colors (CMY+photo black) prints correctly, just pigment black doesn't show on the paper (it is missing from the nozzle check pattern too). The guy, who has given me the printer bought new print head and also bunch of cartridges. I tried to replace the head as well as PGBK ink, but it didn't solve the problem. As I have some experience with electronics, I wanted to try to repair the printer. My first try was to check ribbon cables for the bad connection, but I didn't find any problem there. I checked the connection between motherboard and carriage on pins which I believe are for PGBK cartridge with the voltmeter - it seems to be ok. I have a basic cheap usb logic analyzer, which I could use to check if motherboard produces correct signal, but I'm afraid to connect it to random pins, as I do not know which voltage to expect there. I can rule out head + cartridge as a source of the problem as both were already replaced.
So I'm here hoping that somebody can point me to right direction. My questions:
Is there some relatively common problem (SW or HW), which I'm not aware of, which could cause one ink not to produce output (except of head and ink cartridge)?
Would you guys have some suggestions, how to troubleshoot such problem (I have a multimeter, logic analyser + I could build some Arduino based analyzer to check signals)?
Thank you very much for your kind help.
