user5800
- Jan 25, 2020
- Pro9500 MkII
I would like to know in detail what could be the problem in refilling original OEM cartridges without resetting the chips for the pro9000 mk II, pro9500 mk II and imageProGraph PRO-1000
Because i read this in a previous post and I would like to know more.
I mean aside the fact that you could end up ruin the printhead if you go print without ink left.
I'm interested to understand why the printer should use more ink and fill the waste ink...
In this case should I go for a chip resetter also for the 9000 and the pro 1000? I'm not sure if I can found them
Thanks
Canon have become very active on the chips, and if you run your printer on refills and don’t have a working chip then your printer will waste ink quite a bit.. Waste ink pads fill..!
Thanks
