- Jan 18, 2010
- Residing in Wicklow Ireland
You can wipe the EPROM chip clean by exposing it to UV light, as for how long, that’s another question, then you have the problem of... Where do you get an older firmware and what are the button sequence to achieve this ?
It all goes back to them owing the firmware inside your printer, at one time we could alter this firmware to make the printer last longer, but they have restricted/blocked that avenue off from interference by us users.
If you by chance can enter Service Mode on your printer and either don’t do anything whilst in there, or try to change something out of sequence, then you’ll get an error and failure, and once you leave you cannot re-enter, this only applies to newer printers, older models can still access Service Mode and be saved...
BUT the most important thing to remember, DON’T for any reason upgrade your firmware and only use the print driver that came with the printer, Canon print drivers are for more than just for printing, and never believe what a Canon Representative says...
Its easy to test your printer to enter Service Mode, you apply the correct button sequence and wait to see if the printer responds and enters Service Mode, but Canon have come up with a clever way of stopping you getting any further.Just out of curiousity, does anyone know if the ip7250 can be accessed via service mode to reset the counter?
