- Dec 27, 2014
- Germany
- L805, WF2010, ET8550, T3100X
'handling ' - the samples were not perfectly flat, still slightly curling as they had been cut off a roll some time ago. this may or may not cause problems with the paper feeding in some printers. The paper didn't touch the nozzle plate and leaving black strikes, it was not that bad in my L382. You need to print your pictures one by one and remove the finished print from the output bin and put them away for drying - the glossy paper seems to need more time to dry than the satin and pearl papers - a day or more would be good. And then it's up to you what you do with the prints - spraying - framing - whatever. It's a specialty paper, you probably would use it only in particular situations.
