- Thread starter
- #11
I went back to check the purge unit gears and find I can turn them in one direction only. The other way moves an assembly of some sort that stops at the parking pads and that's as far as the gears will move in that direction.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Now you can start to diagnose your problem with a bit more accuracy.popsy said:I tried the old 'non-working' power adapter, surprise, it worked. I installed the print head. It wouldn't move from the center position.
I powered off and it moved back to the parking pads. I pushed the power button again and got a flashing yellow light and no movement from the p h.
