- Nov 27, 2010
- Copenhagen Denmark
- Canon MP990
I think this qualifies as a destructive test.........The only way to know is a practical (and destructive) test..![]()
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Check this video.There are many mentions in this thread of pharmacist's cart conditioning formula, but I can't find the thread where he actually tells how to use it. I kind of got the impression that you just fill the cart with it then dry the cart. Is that correct?
Thanks
Rest assured, cloudy ammonia will do the same job..Can cloudy ammonia (ammonia with a surfactant/soap mixed in) be used in pharmacist's formula to clean blocked printer head nozzles
May i ask specific question, what did the ammonia does to clogged ink on a inkjet nozzle holes?Many forum members have enjoyed my formula to condition the sponge of Canon cartridges.
The formula is as follows:
-3 ml propylene glycol (or 2 % glycerol)
-20 ml isopropylalcohol
-distilled water up to 100 ml
The cleaning solution to free up clogged printheads is by adding 20-25 drops of concentrated ammonia to each 100 ml of cleaning solution.
Today I suffered from a tenacious clog in my Epson Pro 3800 in the magenta and cyan channel, caused probably by long term of non-usage and the very low humidity in my room because of the high heating since it is now freezing in Belgium. Even after 3 cleaning cycles the clog did not go away. In the past one cleaning cycle is enough to clean minor clogs. So today I folded a piece of towel paper into a nice thick and even strip and drenched it with my cleaning solution and put it under my printhead and let it soak for about 1 hour. After that I executed one cleaning cycle and...all the clogs are gone. Whow it works fantastic and the formula is very cheap to make.
https://www.pffc-online.com/coat-lam/coatings/1828-paper-lesson-amines-usedwhat did the ammonia does to clogged ink on a inkjet nozzle holes?
