- Jan 18, 2010
- Residing in Wicklow Ireland
I decided to tackle this problem of bronzing on the 9500 after a frank decision with Jtoolman.
He has as you know converted one of his many Epson printers over to using clear gloss optimizer in every cartridge for the purpose of overprinting his photos which gave him great results.
So I first decided to convert an iX4000 over to using the clear optimizer
in the single pigment cartridge instead of the usual black ink.
I was so impressed with the results that I decided to convert my 9500 over which has much better control.
Here's how I went about it..
I first printed several different colour photos including the digital dog
and a few test samples about a dozen in all and set them aside for use later.
I had an old green PGI-9 cartridge that was purged of all its ink and I fitted a Matte black ARC chip onto it and then filled it with the clear optimizer.
I removed the MBK black cartridge from the printer and gave the inside of the print head a quick clean with alcohol and a paper tissue, then put in the test cartridge containing the new optimizer.
I decided not to run ran any cleaning cycle just in case the purge unit might somehow contaminated the new cartridge.
I used Illustrator to draw a 200 x 290 mm size box with a 75% black tint in it,
any Application or photo editor will do the same thing, it doesnt matter which one you use so long as you only print to grayscale as I did.
I started the setup with grayscale / normal quality / plain paper and set it to run off 50 sheets of copier this was to make sure I had gotten all of the black ink out of the print head before I could commence my test runs.
It only took 20 sheets to remove all traces of the black ink and for it to print clear,
I was now ready to put my test photos through the printer for the overprinting of the clear optimizer.
I held back one copy of each print sample so I could compare them,
just in case I'd have to increase the amount of optimizer by altering the output quality
or increasing the darkness of my tint. (More or less Gloss needed)
I am happy to report that it works beautifully, youd think the samples had been printed on a dye printer they were that similar, the photos are much more vibrant now and the bronzing issue is history.
When I was finished my test prints I put the proper MBK black cartridge
back into the printer ran a cleaning cycle followed by a nozzle check.
Then I ran the same sheets that I used earlier to clean the print head back through the printer and after three sheets the black was back to normal again, job done.
I have to say a big thank you to Jtoolman for guidance with my test project without his video and patience I wouldnt have tried to this in the first place or to have such a successful outcome..
