Rick76
- Jul 16, 2026
- Epson SureColor P600
Hi everyone,
I'm hoping someone familiar with the Epson SureColor P600 can help point me in the right direction. My beloved P600 has suddenly developed a persistent startup error after 7 years of flawless performance.
Symptoms:
At this point I'm trying to determine whether this is more likely to be:
I'd really appreciate any advice before I start replacing expensive assemblies.
Thank you!
Symptoms:
- Error code is 0x53 about 99% of the time (occasionally 0x01).
- Printer powers up normally.
- Print carriage initializes and travels across the printer.
- During initialization the carriage moves in several small, slightly jerky increments before moving normally at full speed.
- The carriage is not physically stuck.
- After the carriage initialization, I hear the paper feed motor initialize.
- Immediately afterwards the printer stops with error 0x53.
- Carriage slides smoothly by hand with the printer powered off.
- No paper scraps or foreign objects.
- Carriage guide rod is clean.
- Timing belt looks normal.
- Encoder strip has been cleaned.
- Maintenance station appears clean and doesn't appear jammed.
- Cycling power and leaving the printer unplugged has no effect.
- maintenance station drive
- maintenance station position sensor
- carriage encoder sensor
- home sensor
- main board
- something else
Thank you!
