user5800
- Jan 25, 2020
- Pro9500 MkII
In the case I will need to change the 9500 MK2 for another printer, given that the 9500 MK2 is very slow, how are the speed of the PRO-10S and PRO-1000 in comparison ?
On the 9500 MK2 a print of an A3 medium coverage at 4800dpi (high 2 setting) takes around 5-6 min per print, while a 9600dpi (high 1 setting) one takes around 10-15 minutes.
I was drooling over the PRO-1000 since some time, getting one for a decent used price could be nice.
Also, in comparison I was taking into consideration the PRO-1000 because of the following benefits:
- A2 sheet printing
- better tray with the air sucking pumps
- waste ink changeable separately (so no need of a printer potty if I understood correctly)
- no malus on using the ink monitor function disabled, no extra cleanup on refills so that you can just open the cart slot, check the weight before a big batch of work and decide if there's the need for refilling
- 80 ml carts meaning lot of prints before needing of refills
- an estimate of printer life very long, I think that this printer is designed to do likely 2-4 times the number of prints that a 9500 MK2 or 100S could do before dying being also in a plotter line from the bigger models
- have a printhead derived from the bigger brothers, should be the same of 2100 and 4100 models, this sums up to the previous statement expecting a longer life
The 100S advantages are that it could be cheaper, probably around 1/2 or 1/3 of the PRO-1000 investment.
If I get a PRO-1000, there are particular manteinance that I have to take in mind? I would like to use it with compatible inks obviously.
There are bonus and malus that I didn't consider between this 2 models? If you like please write your opinion, thanks
- A2 sheet printing
