I recently got an old IP4500 printer. When I first used it with fresh compatible cartridges it produced a perfect nozzle check print.
As the print head was very dirty with old dried ink and also wanted to switch ink type so I flushed the head with hot water first on the head side followed by the inlet. I did this until no ink appeared from it and it looked clean. I left it for a day for it to dry before refitting it.
With the nozzle print, now I get streaks across the cyan and magenta colour bands
. No matter what I do, like leaving it soaking it in Pharmacist solution or using the same solution in ink cartridges.
I hope I haven't damaged the print head as I read many guides on using tap water to clean it.
Can't afford a new print head costing 60+. Please help?
