- Jan 18, 2010
- Residing in Wicklow Ireland
Here is some interesting news for you guys who use their printer with the ink monitoring totally disabled instead of using some sort of chip for ink control.
I have discovered that my printer a Pro 1 and quite possible most Canon printers act the same when the ink monitoring is deliberately disabled by the user or when using a CISS with no ARC chips.
When your printer is starting up or getting ready to print it will automatic do a clean cycle but what I have discovered is that the printer will waste far more ink from cartridges that have no ink monitoring enabled than the ones that have.
I had a sneaky suspicion of this before and couldnt prove it when I was using CISS systems on several of my printers, but now I have.
I weight all of my cartridges regularly so I know exactly how much ink is in any one of them to the nearest point of a gram.
This printer wastes .25 ml of ink on each cartridge when getting ready to print (Totally acceptable) but wastes a whopping 5 ml. on the cartridges that have no ink monitoring enabled.
So if anyone of you guy want to save your hard earned $$ then use some sort of chip that will record your ink status on screen just as long as the printer is not running blind and trying to kill your print head out of pure revenge..
