websnail has suggested that I post on this forum and get help from jtoolman, so here goes! Hope you're listening!
I moved my Epson 2200 up to my room so I could print from bed (bad idea). The printer started to malfunction. It starts up, but the printhead seemed to get stuck- making a hellatious noise- then all the lights start to flash at once and the printer power light goes off. The other lights continue to flash. I looked around and the cellophane strip that runs along the top of the print head carriage came loose, so I re attached it in the most obvious looking spot. I wonder if I've re-attached it correctly. I've tried to attach a pic but the forum won't let me because I'm a brand new member.
The image is on your server at /forum/uploads/10999_image.jpeg. (I don't know if you can access it there, but maybe the forum will let me post it once this is submitted and approved)
If you have other thoughts on what's going on here, I'd appreciate hearing them.
Thanks so much,
Andrea
Thanks so much,
Andrea
