I have just found this link of the manufacturer of the CR30.
https://www.chnspec.net/Spectral-Colorimeter-CR-30.html
It does specifiy: spectrophotometer and look at the spectral range: 400-700 nm in 10 nm steps, which very similar to the 380-730 nm range of the i1Pro2 (also in 10 nm steps). This might contribute to the very good results in generating RGB-printer profiles with ArgyllCMS. It should be superior to the Spyderprint device that only uses color filters to establish the LAB-values (not a true spectrophotometer).
knowing
HP CLJ5550, Brother MFC-9460
The software runs on Windows only and needs a com-port: maybe a virtualisation is possible in MacoS. The software is called ColorQC2 and is necessary to capture the LAB-values and the spectral data needed by ArgyllCMS to create the printer profile.
Ok, thanks.
I have made a new A4 target with pseudo-scrambled patches for the CR30 with 300 patches and 21 grey steps. I will upload it later with a rudimentary how-to manual if I have some time, because it is rather busy at work now.
Epatcola
various
Update to target and profile generating batch files and scripts.
The ti3 generation script didn't properly handle targets with more than 26 columns.
Also included is a csv file from ColorQC 2 for a 728 patch target. You can use this to go through the process of ti3 file and profile generation and checking.
  • Printer profile generation with CR30 and Argyll.zip
superjudge
New Printer Member
ET-8550
Long time listener, first time caller. I tweaked the batch files in Epatcola's AWK scripts to generate 10mm patches using -a1.25 and set it to create 25 patch columns on letter-sized paper. Made it WAY easier to scan patches for me after trying repeatedly with 8mm patches. I was able to fit 450 patches on one sheet of letter, and it resulted in a profiles that I'm honestly VERY happy with. I was getting a lot of jaggy edges on the visualization for the 300x8mm patch scans.
you're welcome. Happy to see another person able to generate a printer profile using the CR30 colorimeter.
