Epatcola
- Mar 21, 2020
- various
I am using 8mm patches and the rule I designed so you only need to see a couple of patch 'joints' to align the rule.OK, so for the moment only non-randomized patches will work. This is not a big deal, but when using several grey steps, because the hue increased with each following patch with a little but and sometimes without spacebars it is difficult to determine the end/beginning of the next patch. Therefore I have uploaded a modified i1Pro based target with tiny space bars between the patches making it much easier to determine where the next patch is starting.
I have never had any ti3 files from chartread to look at. It appears the colprof needs the input RGB values (from the ti2 file) followed by measured values on each data line. I don't see that colprof needs SAMPLE_LOCs for anything. What it does need is the RGB values for a line followed by the measurements from the patch associated with the line. I think the simplest way to achieve that with randomized targets would be to sort the data lines of the ti2 file on SAMPLE_LOC. I will try that.
Also I don't see anything wrong with the csv files ColorQC writes. Comma separated with decimal points in numbers. Did you have it mess up using commas instead of decimal points? Probably some locale induced crap.
