- Nov 3, 2004
- Bay Area CA
- CR-10, i560 ,MFC-7440N
It's funny because it is true!panos said:Here is a photo (to satisfy Rob's voracious apetite for photos)
That's because you've overfilled them by allowing/forcing the sponge to absorb ink right to the top. I see a lot of people obsessed with removing every last bit of air, even from spongeless cartridges, and this defeats the ink pressure regulation of the cartridge.Grandad35 said:JV,
Since purging my carts I have noted that the refilled carts drip a few drops when they are first removed from the storage clips (as was reported earlier for the Wired Beans carts). This applies equally to OEM, Old IG, New IG and Wired Beans carts. This isn't a problem as long as you expect it, and I take this behavior as a positive indication that the cart is not starving the ink pickup. Since I also switched bulk ink suppliers at the same time as I purged the carts, I can't say whether this behavior is caused by the clean carts and repositioned sponges or if it is because of the new ink. Have you noticed similar dripping with your inks?
I tend to disagree. After I first purged my carts they tended to drip. This is no longer the case after (on average) 5-6 refills/cart, even though they are still "overfilled" to the same degree as before.AlienSteve said:That's because you've overfilled them by allowing/forcing the sponge to absorb ink right to the top. I see a lot of people obsessed with removing every last bit of air, even from spongeless cartridges, and this defeats the ink pressure regulation of the cartridge.
But the -sponge- is not full to the brim. Nothing wrong with filling the spongeless tank side to the brim.panos said:Here is a recently refilled cartridge. It doesn't drip, although it's full to the brim.
