- Oct 27, 2005
- South Yorks, UK
- Epson, Canon, HP... A "few"
Yeah that's a standard problem with the multifunctionals.. The lid can cause the tubing to act differently and drop into the path of the carriage so getting just the right amount of slack and tension is a little trial and error.GLO said:Quick update.
Everything was working fine whilst i had the scanner lid open.
Once closed i heard a loud grinding (not good), which was the tubing blocking the carts whilst the lid was down.
I managed to fix thisby tightening up some slack on the tubing, so know its all running smoothly again.
I think everyone does this at least once in their CIS lifeI primed the carts again (didnt to it properly before) and only left a real little amount of air in the carts.
Re: the slight angle.. it's possible that you need to retune the tubing and cartridges as they may be causing the printhead to shift a small amount.. Unlikely and to be honest if it isn't actually affecting the output I'd not stress about it just yet.But my dilemma now is that the colours appear to be a bit washed out.
Im not sure if its because the ink run mak be a little too restrictive, but the nozlle checks are 100%, but the horizontal lines in the grid are on a very slight angle. (i thought that an alignment would fix this, but it didnt, however all other lines and text appear fine)
As to the washed out colours, you should be able to adjust the colour output a little in the printer properties with some trial and error. Ultimately though it's often the inks themselves that aren't that great so consider using what you have up and getting some of the stuff recommended by various people on here once you're happy with how things are working..
One thing I would warn you about though is that you need to try and avoid playing around too much with the unit.. I've managed to blow an iP4000 printhead because I clamped the tube feeds and forgot to unclamp them causing the ink to run dry and the unit to overheat... So just remain calm, patient and be careful to triple check everything..
It does sound like you got a hell of a lot further along than I did when I was working with the MP750 though so well done.. It's certainly not easy..
e first time i did this i did not get a good seal and i had a few drops of ink to soak up.
