costadinos
- Nov 16, 2012
- Location
- Cyprus
- 7900, 4900, 9890, R2000, P50
I recently needed to print several borderless 12"x16" prints using an Epson 1400. To my surprise, while the printer driver supports 12"x12" square borderless prints, it wouldn't let me define a custom length (the same is true for all supported borderless width settings).
That's something you can do using other printers, like the R2000, R2880 etc. The limitation to a borderless print is simply the width, you can manually set any length.
Does anybody know a workaround to this? I know I can print on wider paper and trim, but that's not the point.
Or, just in case it's a driver issue, can anybody using the US version of the driver/printer check and see if that's a limitation with that version as well?
