Canon waste ink
Thought I'd share this article and open it for comment for anyone in the know for corrections, etc..
http://www.octoink.co.uk/store/pages/Canon-Pixmas.html
Basically it's a distillation of what I've picked up about canon printers in relation to waste ink with a healthy dose of input from Trigger 37 regarding the pump capabilities.
Ron350
Alabama
Thanks Martin that is a good article.
Smile
Europe EU
Well if you take each cli-8 cartridge and put a drop of (ammonia 10%) 0.2ml with insulin syringe on each cartridge.Then insert cartridges and perform cleaning procedure at then print purge page, then nozzle test, then pirge page.
Repeat a few times.
This will prevent clogs in you waste ink tubes head nozzles.
Repeat a few times.
Would it not just be easier to flush the extension tube with the same solution every once in a while to stop any clogs developing in there? From experience the clogs don't develop in the existing system unless you allow ink to pool there which would be difficult given the shortness of the tubing in the ones I've looked at.
lin
Different canon printer (performing automatic cleaning cycle) auto purge different amount of ink at different interval of time lapsed/ replacement of ink tank/removing of PH etc..... Just how much inks were deposited to my canon waste ink pad after many hours lapsed. On my machine, the manual indicated these amount of ink will auto purge when those hours had lapsed. As more time had lasped, slightly more ink will be used during the auto cleaning cycle. Below is a small section of my printer manual on the cleaning mode.
Since at 120 to 336 hours lapsed from the previous cleaning, will generate the same amount of ink purge as a manual cleaning perform, below is a simulated case of auto purge cycle perform at 120 hours time lapse by executing a cleaning cycle.
Now if there were clog in Printhead and deep cleaning cycle were executed, below is the amount of ink which my printer will be deposit to the waste ink pad.
Someone did a similar test to see how much ink will be purge out when executing a cleaning cycle on Epson R270. As there is no option at the maintenance utility to select cleaning cycle or deep cleaning cycle like Canon, the amount of ink purge out by executing the cleaning cycle was approximately 3ml.
Thanks for that info lin... That would jell with the observations I've made with the iP4000 I modified some time back.
About the only thing I'd say here is that my experience with the C8x models is that they push out at least 3ml on a cleaning cycle and in terms of requirements they tend to need cleaning cycles around 4 or 5 times more than Canon pixma's.
The CX6600 I bought for testing was the worst I've ever seen though with at least 5ml of waste ink in every cleaning routine. No idea why but it was a VERY heavy waste ink abuser.
Smile
Europe EU
Very good test "lin" I was looking to do some testing like this too.
When you start to think that you turn on a printer 3 times a day at least, x 30 days = 90 times a month. If average amount of ink is 00.9ml than that totals to (00.9 x 90 :) 8.1ml of waste ink.
If the printer uses 5 carts that means each will lose about 1.62ml.
And this is just to turn the printer on?
Can't find the original thread(s) I've posted on, but just to note that I've just completed a mammoth photo set for disassembling an iP4200 and fitting an external waste ink kit.
It's taken 3 hours just to edit the photos into something usable.
I'll post up a link to the finished article (hopefully tomorrow - Sunday, or sometime this week) if/when I get enough time between nappy changes and naps.
qwertydude
Canons may waste less ink per cleaning but on the newer IP4600 they make up for it with cleaning cycles galore. Pretty much every time you turn it on it seems to go through a cleaning cycle.
