Canon Inkjet printhead connectors (scans & photos)
Łukasz
Poland
MG6250 (MG5150 before)
Hello,
I would like to start picture collection of printhead connectors from Canon Inkjet printers.
And I ask Everyone to join, cause I have access to very limited types of printheads.
Let's go with very popular QY6-0080:
Suggested scan parameters:
- no auto corrections (sharpening, etc)
- image type: none or photo
- resolution: 600 dpi (or 1200 if you wish)
- file format: PNG (or other lossless)
- scanner type: CCD is better than CIS
Ł.
Here is a scan of the contacts of a QY6-0061. This print head is used in iP5200 and MP830. An extended service manual for the MP830 with the pinout does exist. It is found here.
I have more print heads, do you want scans of them all, or only these for which pinout exists?
Łukasz
Poland
Thanks!
Each printhead is appreciated :thumbsup
There is a chance to determine the approximate pinout for "unknown" printheads (or at least some of most important contacts).
Ł.
Here is the QY6-0059, it is used in iP4200 and other printers. A service manual for iP4200 with pinout is found here.
Emulator
Canon Pro9000 II
Here is the QY6-0076 from the Canon Pro 9000 II
This is the QY6-0049-000 i865
This is the QY6-0066-000 MX7600 iX7000
This is the QY6-0077-000 Pro 9500
Łukasz
Poland
Excellent! :thumbsup
I managed to run old CCD scanner - Plustek OpticPro 12000T.
PC with specifically configured parallel port was necessary.
Scanner was put out of action many years ago because of power adapter failure. But now it is connected to IBM Thinkpad power adapter (16V, original was 15V).
Filed depth is fine, but colors are terrible. Max optical resolution is 600 dpi.
Compared, scanner unit in modern Canon Inkjet is a pleasure to use.
Here is QY6-0073 connector:
It is nearly same as QY6-0080, but it lacks two HV grounds.
Also, 2 +3V pins are connected in different manner (QY6-0073 is "old style" with dedicated "bridge"):
Ł.
Here is QY6-0042, used in i560 and iP3000:
Here is QY6-0043 used in i965:
Here is QY6-0053 used in i990:
