- Thread starter
- #41
- May 29, 2007
- Ghent, Belgium
- Epson SC-P800,WF-7840,XP-15000
Hi Roy,Roy Sletcher said:Hi Emu,Emulator said:Roy, From my brief experience of the results of both CM and Argyll, I think you would be equally happy with either.
At the moment am using the colormunki for my print profiles and very happy with the results using IS inks. Also, it is quick and easy to use, and produces excellent profiles despite the small number of scanned patches..
I had been previously using the Spyderprint 4.2.3 and was not happy with the results.
I am reluctant to change to Argyll and endure the learning curve unless I can be reasonably sure it produces better profiles.
From what I am reading so far the difference is so small as to be almost unnoticeable.
Roy
actually the advantage of the ArgyllCMS method that reading is done in a single step. The profiles are equally good, better than the CM method (using 2 optimizations) in the grays. Is it difficult: not really. I made a batch file called makeprofile so I get an interaction for input for internal name, file name etc instead of using cryptic descriptions.
Out-of-gamut colours are bit better reproduced perceptually compared to the CM-profiles (more vivid). ArgyllCMS allows you to create profiles for others and not bound to the software license of X-rite. Also the two-step method of method makes it very inconvenient to make profiles of others as second target is depending on the readings of the first target.
I had a SpyderPprint too before and the results are very inconsistent with the dreaded blue-to-purple shift in the profiles. Despite the hue-manipulation of the target does eliminate this problem at the cost of making purples more blue...
