- May 29, 2007
- Ghent, Belgium
- SC-900 ET-8550 WF-7840 TS705
HI Martin: you should open a command shell and type that makeprofile.bat. Just clicking on it won't work.
Just don't use the 480target.bat to generate. My package is complete: it contains everything you need: target and the necessary files from you which you can generate your profile.
Please have your profile properly dried before reading. For some dye printers 24 hours is necessary to stop color shifting after printing.
Just make sure makeprofile is accessible in your path setting. Also make sure that a copy of adobe1998.icm is in your working directory.
So you put all the files: 480target.ti1 and 480target.ti2 and adobergb1998.icm in a directory.
Install argylllcms and make sure that your argyllcms is in your path setting of windows (see installation guide of argyllcms).
type:
Chartread -v -H -T0.4 480target
Now just read the target. When all patches are read, type d, to save the reading and close the command.
Afterwards you type: makeprofile
you will get the following warnings:
Please enter the internal ICC file name (use brackets like "x x x" for names with spaces):
(for example: My_profile_with_Argyll_CMS or "My Profile with Argyll CMS")
Please enter the (optional) copyright description (use brackets like "x x x" for names with spaces):
(for example: "Nobody has the right to distribute this profile" or nothing}
Enter the name of the .ti3 file created by the chartread command:
Here you should enter: 480target
Please enter the desired external name of your printer profile:
(for example: "My Profile with Argyll CMS")
Than it will several minutes for your computer to calculate the profile
that's all folks
type:
that's all folks
