Magician is used to install the special Samsung cache algorithms that use system RAM that enable the SSD to be even faster in certain situations.
Windows has been doing this - virtual memory or caching - for years.Magician is used to install the special Samsung cache algorithms that use system RAM that enable the SSD to be even faster in certain situations.
So the MB and SSD manuals had nothing about this?The boot up time has been erratic and the system keeps resetting the boot drive to a HDD and a slower time. I have eventually discovered, with the help of the web and not the manual, that the boot drive is determined by the physical SATA socket order used on the motherboard and not by the BIOS!!
It seemed unlikely but it works. It now boots from the SSD.
Insert the SSD, fitted with the bracket, into the location of
the original HDD(usually SATA port #0), and secure it in place.
The HDD is usually mounted in SATA port #0, because booting starts at the lowest-numbered SATA port
and then proceeds sequentially. (Port #0, port #1, port #2, and so on.)
Therefore, you need to mount your new SSD in SATA port #0 (vacated by the existing HDD), which is the
lowest-numbered SATA port.
@Emulator:
You beat me to the post.
It is the SSD manufacturer, not the motherboard manufacturer, who should inform the consumer about installation of their drive. The motherboard manual should tell you which SATA port is from what manufacturer and of what number (port 0, port 1, etc).
For instance, the owner's manual for the Samsung 840 Pro state:
If you have only one drive - the SSD - in your computer then you can use any Intel SATA port.
One other point is to use an Intel SATA port and not another branded port such as Marvel. Not all SATA ports are equal in function.
