- Jan 18, 2010
- Residing in Wicklow Ireland
There is you know, all you have to do is to hit print and the printer will turn itself on unaided..
Well what do you know -- there is a Power Off button in my Maintenance tab as well! Must be from the Windows 8 software I loaded for my new computer because it wasn't there all these years with my old computer.Me neither I was very pleased to see the command in the "My Printer" utility. Pity there's not a "Power On" command!
Pushing the Power Off button when the printer is turned off already does not toggle the power back on. Neither does The Hat's suggestion of trying to print something.
It's all well and good for me anyways as I've a custom made cover for my printer and have to get up and go over to the printer to put it on when powering off, so I won't be using the software Power Off. But still a great find that was right under my nose the two times I went into this Properties/Maintenance tab and it didn't register as I was trying to just get something done and move on to the next task.
PeterBJ said:the hat is right. It is actually possible to set the printer to automatically turn on when a print job is sent to the printer, whether you are using Windows XP, Vista, 7, 8, or 8.1
It’s alright PeterBJ, stratman is still trying to join me in Orbit, He’ll get there eventfully…Stratman said:Pushing the Power Off button when the printer is turned off already does not toggle the power back on. Neither does The Hat's suggestion of trying to print something.
I like the way you think!<snip>
<snip>
Yes, same with my MX328. Ah well, I have to walk past it after I turn on the UPS, so it's no big deal really!<snip>
<snip>
There is no such button on my 6700D, ip1600, ip6210 etc.?
But it is available on ip100, ip3000 hmm very strange.
The reason I want to power it off when I shutdown the PC is that after I shut down the PC, I turn off the UPS. So the power to the printer gets cut while it is on.
But I've noticed that if I hit the "Power" button on the printer while it is on, it does some housekeeping (maybe parking the print heads?) before it actually switches off.
So I thought it better to play nice and make sure it powers of properly - using the command from the PC - before I turn off the UPS. This saves walking to the printer and back to the UPS.
Do NOT just use your UPS to cut power to a printer that is turned on. Use the printer's off button (or this software one if available) so that the print head moves over and parks directly above/on the purge pads.The reason I want to power it off when I shutdown the PC is that after I shut down the PC, I turn off the UPS. So the power to the printer gets cut while it is on.
That is the fact. The MP830 does not have this "Auto on/off" button. If you click on Help while on the Maintenance tab you may see as I doI just checked the maintenance tabs in the printer properties windows for all my Canon printers installed on a Windows 8.1 64 bit computer.
the iP6600D, which I think is similar to the iP6700D only has the power off button, no Auto on/off button. So it seems this feature is not available for all Canon printer models.
Auto Power <Applicable Models Only>
