[Tool] ChromIQ – a macOS and Windows GUI for ArgyllCMS printer profiling (v3.9.0)
itsab1989
Epson ET 8550, Canon Pro 300
I don't see the margin settings for patch width/height either:
Just tried it on my Windows VM and you are right. Activating the engine in settings does not really activate it. I'll check
Edit: Update should be coming soon (beta 22 - not 21).
Edit 2: beta 22 should be online in a few minutes. Might need to turn it off and on again for it to work. the settings you make in the settings window auto save for the combination of instrument, paper and mode and you can recall them from the create chart tabs manual module.
Will sleep now and probably take a break of a few days from this.
I just played a bit with the latest beta versions and I am impressed by the patch layout engine:
No photoshop needed to get a margin of 26 mm on the left and 38 mm from above, while keeping the patch layout of 24 rows of 31 patches with a minimum patch width of 7.5 mm: 744 patches on a single A4 sheet.
itsab1989
Nice that you like it. As always it needs some improvement. But one big point: I have not yet tried to measure such a chart to see whether the ti2 files for it are actually correctly created for this
Ok here is my update:
After creating the profile and softproofing:
The softproofing is perfect no strange banding whatsoever. Approved !!!
Well, I seem to have a knack for triple-checking my settings, getting unexpected results, and concluding that something is wrong, only to try it one more time and seeing the problem disappear. Here's a new print from the same 1944-patch profile, settings identical to before, looking very close to the 1100-patch with refinement.
Did you find the culprit of the problem causing the previous magenta cast ? Anyhow the number crushing method of sampling the area around the neutral axis does help to find the exact neutral axis for a given printer/paper/ink set combination without the need of a preconditioning profile. This is the reason when choosing a patch count to generate printer profile always emphasize the neutral and near neutral axis as this is visually the most important area for a good profile .
pkk
St. Louis Mo.
Canon Pro100 Epson 3880, 9880
I‘ll check it when I am at home. When you say the Colormunki profile was not successful either - how bad was it? A colorcast or like really really really bad?
Well, I would call it unusable, similar to the other failures. The odd thing is, they are either very good or very bad. I've been looking at the profiles I've made with the LittleArgyllGUI and none of them are as good as the two successful ones with ChromIQ. I can send the ColorMunki files if they would help.
itsab1989
Send them and I‘ll let Claude check. Maybe it finds a hint.
