Saving a Canon pro 1 printer, one day at a time
Cassiop38
Epson, Canon, HP.
So... I have now enough ink to try a rescue on a Canon pro 1.
Symptoms : print blank pages /nozzle checks, no errors.
Current plan : power up the printer, unplug it so the printhead move freely, rube the printhead over a octoink cleaning solution for canon soaked towel paper.
Replug the printer, do a simple head cleaning cycle, try a nozzle check.
Worth to be noted : i removed the 12 cartridges to feed pgi-72s and i'm a tiny bit worried that ink could have clogged the ink inlet. The tiny tube that goes inside the pgi-29s to suck ink. I could probably reach them with IPA soaked... Thing stick you put in your ears, cant remember the name. Should i ?
All suggestions are welcome,
Thanks !
Cassiop38
Epson, Canon, HP.
Eeeeehhhhh much better !!!! Agreed, still suboptimal.
Cassiop38
Epson, Canon, HP.
Small update after this sequence
1 small clean, 1 manual clean, 1 deep clea , 1 manual clean, 1 small clean
Now, we wait.
Manual clean was rubbing the printhead over towel paper soaked in IPA and octoinkjet thermal printhead cleaning solution. R, PBK and MBK are very dead but as was M and Y not so long ago. I'll come back tomorow.
Cassiop38
Epson, Canon, HP.
2nd update.
I removed the printhead from the printer to soak it into cleaning solution. i'll skip forward doing that 2 times and ran a bunch of cleaning in between. So everything is starting to looks good except PBK.
I tried rubbing the nozzle group good, tried to force push ink into the PBK's inlet of the printhead (and ended up a small ink explosion that stained my desk and me. (i was feeling stupid wearing gloves and a chemistery jacket. i'm glad i did ! next time i put safety glasses too.)) but i wasn't able to push ink throught the nozzle that way. I didn't tried to do that with another color but i will. Just to see if it is possible or not. (And since the head is pressurized while printing, that would makes sense that it is not possible.)
Anyway, if you guys have suggestions, i'll be glad to ear them !
Cassiop38
Epson, Canon, HP.
Thrid update
So the PBK Wasn't printing.
Well, that was why.
So i took the head apart for sport and found why the pbk wasn't working. It roughly clogged everywhere possible. I took a bunch of pictures of what is inside. Quite interresting that there is basically cartridges inside the printhead and that the feeding channeks look like, in the end, our regular cartridge based printer's.
Here is a pic of the small double cartridge. On this side it is PBK, you can see partickes everywhere that are responsible for the clog. On the other side it is DGY (i believe) which us liquid..
Cassiop38
Epson, Canon, HP.
Hello folks, today's update is about pumps.
I don't like them. I managed to put the printhead back together and it is now empty (filled with air) and clean. I wanted to purge the tubes as well so i rinced/cleaned a pgi-29 cartridge and filled it with IPA (or water, i don't remember and it doesn't matter yet as the last purge will be made with IPA anyway).
The plan was to plug the cartrige and pull/suck ink from the printhead side. Obviously it didn't work because there is PUMPS in the middle.
I'm now facing a three choices problem.
1 - i do nothing. Easy, unreliable
2 - i purge each side of the pump. Not great, not terrible
3 - i dismantle the whole pumping units and see what happen. I don't want to do this.
Any means to have the pump running in service mode with the printhead off ? Guess not because it would be soooo conveinient
... Anyone know how those pumps works or are mounted ? I saw them but i'm afraid by the amount of dismantling required to reach them.
Pumps are mounted of the other side of the green PCBs you see on left and right, just above the front paper tray.
The best advice I can give is to find a dumpster big enough for the printer and be shot of it…
Cassiop38
Epson, Canon, HP.
No no no no no. That thing is gonna work again, with or without its consent.
But i must admit, i had several weird hobbies but this one is breaking records.
Do you know if the service manual was leaked somewhere or a thrustable source i could buy it from ? I'd like to check how pumps are hooked before trying to dismantle that part. There is a compressor somewhere and i don't know where. I'm afraid it is on the feeding lines but i don't guess how...
