How to use an unlicensed i1Pro spectro with i1Profiler and ArgyllCMS
here you are. You will surprised how good this small target is: you can hardly tell the difference with the larger patch sets.
  • Chart 192 Patches 10x15 cm v2.zip
mavtop
Epson XP 15000
Thank you very much @pharmacist i will have a lot to test in Christmas time:
- some ancient HP Baryte Satin Art Paper (it tells for pigment inks, but i will try with dye) i have in A3+, 610mmx30m rolls and 1118mmx15,2m rolls
- some old A3+ Arches Textured Cotton paper (i suppose it is Hahnemuhle paper)
- a lot of Fujifilm Fuji Hunt professional Paper in rolls, Semigloss, Glossy, Matte and Luster
- a lot of Epson Paper in A3+ and rolls Semigloss and Luster
and a lot of others A3, A4 and rolls, some unknown too
i don't know if i will have the time to make all the profiles, but i wanna try, your ruler and iProfiler, maybe i can have better feedback when scanning so i can get the best way to do it.
When i will have some time i would like to know how you generate these target sheets, which software are you using (ArgyllCMS or Xrite software) ?
If Argyllcms i would like to see your parameters, just to understand how to create them, i would like to create target like Keith Cooper does, with a row with a lot of Green gradients from low to high, Yellow, Orange, and almost all colors, more a white,black,grey gradients rows.
I don't how many patches will be required, but i can't find an option in ArgyllCMS to do it easily, the other problem is that if i run the generator several times, each time i will get a different target patches set, maybe i have to use a switch that don't use random, but i don't know how.
