You don't need much patches to create a good printer profile
OK, I will have a check. Maybe you can tell me which patches are doubles, so I can change them. Thanks for the feedback.
PaintShop just gives me the number of unique colors - nothing more - no value or location in an image file whatever.
But I could find a way to export the patch file data from the i1Profiler editor as a tab separated text file with the RGB values but again no location data within the patch sheet but it most likely arranged in a left-right - top - down scheme in a sequential table.
  • Chart 192 Patches.txt
I think I might have found the doubles and removed them. I think these are the last 6 RGB patches (with different hues) before the near neutral patches. I replaced them with extra near neutral patches. The pink outlined boxes are the doubles I have detected.
The new target looks like now:
  • Chart 192 Patches 10x15 cm.zip
  • Chart 192 Patches 10x15 cm i1iO2.zip
@pharmasist - it works - I printed your 192 patchsheet on a 10x15 cm card and scanned it with the i1io2 robot - it works !!! - that was some great work you did to create the necessary parameter files and patch sheet.
I hope you will report back and see how this target will perform compared to a larger patch size target like 729 or even 2880 patches. If the average difference will fall under Delta-E 1, than it is practically indistiguishable compared to much larger targets. The 165 patch target was already satisfactory (thinking it has a few doubles too, making it a 159 patch target). I think it has twice the amount of patches of your 96 target. Note: GretagMacbeth original simple printer target has only 45 patches (eye-one match):
I expect a marginal change for the DeltaE 165 vs. 192 - value only - in the range of reading noise/variations behind the decimal point. Let me see.
Let me mention the DeltaE numbers of the last test - I did in this case compare the patch prints done with the 720 patch profile and the 192 patch profile - on the Netbit paper - it is 1.3. There was a problem with the prints on the Action paper - there was a defect spot in the coating on one sheet driving up the DeltaE to 3.5 making this number meaningless. We are looking to deltas of deltas - and I'm glad that numbers are consistent so far so I'm not redoing the test on the Action paper - the small patch sheet with 192 colors delivers already a very good profile consistent with the other numbers, and I'll go and use it as appropriate.
Nice to hear. So according to you most will be more than satisfied with this miniature 192 patch target. That would be very interesting for a fast target to try out aftermarket ink/paper combination without spilling too much paper/ink/time to get good results. Now maybe I should produce a half size A4 AKA A5 target patch sheet with around 400 patches or even a 13x18 cm fast target set (maybe 300 patches ?).
I appreciate the optimization of the 10x15 cm patch sheet to 192 active patches very much, but I actually don't really need much more of that with higher patch counts. You may have a look to some improvement for user doing the manual scan with the original scanning board - e.g. larger patches or or ........whatever . I just let the i1io doing the job.
A A5 patch sheet may be of help - I sometimes do multiple profiles to see if driver changes make a difference - paper selection - quality level.
