thebestcpu
Printing Ninja
- Dec 8, 2024
- Epson SC P900
Yes, that would be absurd, and I did not use the words you quoted: "not as intended" and instead suggested that full characterization is needed and YMMV. Case in point, Keith found that using ABW in the FVA mode was worse (blocked up shadows and worse Dmax), and Jose saw that for his color images, he saw positive improvementsI mean this speaks to the printer controlling the ink delivery drivers, and ICC profiles needing to work around that.
When using other papers and other printer profiles, you need to select the paper type which mirrors the name of epson's OEM papers, i.e. Epson VFA or Epson Ultra Premium Glossy. I don't think it's "not as intended", unless you want to suggest using these printers with any paper otherthan epson's specific papers for which there exists a paper type is "not as intended" and/or a hack... Which would be absurd of course.
Keith did and always does excellent work, and clearly went way beyond creating a new ICC profile and measuring Dmax, along with providing appropriate caveats and cautions when characterizing papers for specific printer/inks/media modes.
I have no illusions about companies giving up on those abstractions and understand why. Marketing and sales want to make the biggest and best impressions to compete and make sales. If you have ever seen my other posts, I believe in testing to strip the marketing words out and find out what is really going on.Really it would be nice if ICC profiles had more control over the printer drivers, but that could also introduce a whole other can of worms: standardization, settings, etc. Nor would the printer manufacturers necessarily be enthusiastic about giving up this level of abstraction and control, and nor necessarily would it benefit the average joe who walks into best buy, picks one of these up, and just wants prints as fast as possible.
If you look at Jose's video: to his eye the results are improved. Possibly new ICC profiles could be made exploiting the VFA paper type to take advantage of the pigment and dye ink usage.
I agree, and if I rained on anyone's parade, I apologize. I think I focused too much on Keith and Jose using the words almost imperceptible" improvements when I was hoping for a "breakthrough."
Yes, I do use OEM paper, ink, and profiles. Thanks for your tip.Do you use OEM ICC profiles? I found the QIMage ICC profiles for OEM papers (and OEM inks obviously) produce significantly better results than the OEM ICC profiles. I also checked the OEM ICC profiles in colorsync on my computer, and found them to be completely identical, so there's obvious room for improvement there.
