- Feb 4, 2014
- Belgium
- PRO10,PRO9500II,MB5150,MG8250
Strange that the MBK nozzle check was OK before and suddenly failed 100%.
From what I've seen the PC and GY issue at the beginning of the thread is probably cartridge related.
It builds up gradually and can be identified at an early stage with a magnifying glass.
It should disappear at once when inserting another cart.
I suggested to clean the carts and refill with the same 3th party ink, since replacing with OEM would mask an additional problem in the printhead (supposing OEM ink can cure it).
There is a reasonable chance it doesn't come back with a thoroughly cleaned cart.
Both cart and printhead issues could have been built up together after 2500 pages.
Reason of the cartridge issue could maybe be found by dissection.
PS: personally I refill (6 years) by dripping on a scale until 32.5g (and squeeze eventual remaining air/foam out), store carts outlet down.
Never had issues with the PRO-9500II, the PRO-10 seems to be less tolerant.
