ColourKid
- Jan 13, 2020
- Various
If you print photos (on photo paper) then you use the dye-based black (denoted K often times I gathered) instead of the pigment-based black (Bk). Now when does this "photo black" actually get used? Is it only for the parts of the photo where it is completely black ("true black")? Or does it also do some dithering to make other colours darker?
If it's only for the "true black" parts then I ask: what use is that? Since a photo is on average never truly black in 99% of the photo, it would use the colour inks (C, M, Y) for the majority of the print. In that case it might as well use a mixture of CMY to create black as well. That is, unless you photograph something way too under-exposed or if you are clipping your colours on the low-end, in which case it probably gives a better result to use a photo black for that.
So I suspect the printer uses the photo black also for making the colours darker. Is that true? How does that work? It just prints some black dots in between the colours? But would that not lower the quality actually since it cannot mix colours on the same spot on the paper? That is, you can only "dither" the true black in between the other inks, you cannot mix then since it will come out black anyway, which seems worse than just mixing the desired level of brightness using CMY. A grey dye-based ink then I would understand (which indeed some photo printers have) since you can use it to lower the brightness and then adjust it by mixing it with the colours. Or can printers also use lower droplets of black ink to truly mix a colour somehow (while it's still wet?) such that it becomes a colour instead of black? Can some expert reflect a little bit on this? Thanks!
BTW, I was a member of the Nifty Stuff forum before but apparently my account was lost, so thanks for having me back.
