Trying to Fix my L1800 - Looking for Advise
GoldenCooper
L120/ 1800 / 805
Hello Everyone, I've been reading alot from this Forums and I must say, The knowledge I've learned from everyone is priceless.
I've been trying to make my L1800 is not working properly.
I dont have much as far as resources are concerned and this workhorse printer has been earning me to make ends meet. I need to make it work.
During a decolgging session, I am guessing the connecting port to the head got wet and shorted. However I am not sure.
Currently the printer does turn on, prints but no ink comes out. When i power flush the ink comes out of the tank. I'm sure the heads are clean but again nothing comes out.
I have tested the main board and checked on F1 (which someone told me is the fuse for the board) and a multitester registers continuity. which i suppose means the fuse is intact along with the board. I also checked the flex cable that goes to the printhead, it looks like there is a burnt out part, however the tested registers for continuity.
Which leads me to conclude that the Printer head is faulty?
I'm wary of trying out a new head as it may just end up shorting it.
Questions:
1. Is there a way to check on error code if the printerhead is shorted?
2. Is there a way to solder or repair the printerhead? Obviously I am trying to save money
3. I've seen China copy cat printheads out there , are they worth it ?
here are some pictures of my work. See attached.
Yes, I have an L1800 , but never any problems similar to yours.
You might look for a Service manual to get further , a link here by @PeterBJ
https://www.printerknowledge.com/threads/rescued-artisan-810.12201/post-105234.
There are other locations as well which will charge you for such manual.
You can try to run the WICReset utiltiy, which would give you a list of recent error codes and a one line explanation to those which might help as well in this case.
As long as you don't know whether there is any damage, not just a fuse, but e.g. some channels in a driver chip on the motherboard etc I would not consider looking for another printhead yet. I don't think it is clear enough yet what and where the problem is.
You mention an unclogging action, what type of inks are you using , I do not experience any significant clogging at all with any of my L.. and ET.. tank system printers other than by gross negligence on my part, with dye or pigment inks.
tricks
EPSON L1800
Questions:
I HAVE THE SAME PROBLEM...
DID YOU SOLVE THE PROBLEM? CAN I ASK HOW YOU DID IT
