- Thread starter
- #21
You obviously weren’t following my posts that closely because nowhere did I mention a system clean,but I did want you to run a deep clean only and see how that went, because when dealing with a severely clogged head small steps are best, a deep clean only uses 10% of your ink.im following everything you say, but the one thing that did the business was a system clean on the PBK ink bank...
Compatibles vs OEM -- depends on your tolerance for accurate color reproduction. With compatibles, or refill inks, a printer ICC profile created using the Pro-1 along with one specific inkset and one specific paper can provide wonderful results. But, an ICC profile costs money, whether you do it yourself or have someone else do it for you. There are free ICC profiles for the Pro-1 but these must use a specified paper and ink (eg Red River Papers)do i now bin the compatibles and get the oem's and also a spare print head
But and this is very vital, only if your printer can enter Service mode can you carry out this procedure, and this is only possible if the printer is old enough, (Pre 2013) and I did noticed your nozzle check didn’t have a page count on the very bottom, which is very positive.
The printer is designed / optimized to use OEM Canon inks and paper. You may try other paper by different manufacturers but then there is no guarantee of color fidelity (or gloss differential, ie bronzing) unless you use a printer ICC profile designed for your printer model and the specific inks and paper used. Change any of the three variables and a new ICC profile will be needed.do i stick with canon paper
As I said in my post above, some paper manufacturers, such as Red River Papers, have printer ICC profiles their specific paper and your printer model but only when using OEM Canon inks. Precision Colors offers some free ICC profiles for your printer, PC inks and certain papers.will the software carry profiles for other manufactures papers ??
When the waste ink counter reaches its maximum then the printer will cease to work. If you have a newer model then you will not be able to enter Service Mode and reset the waste ink counter. Unless a new tool (software) becomes available in the future to do this on your own then you will either need to take the no longer working printer to a Canon Service Technician (expensive) or use it as a paper weight (bin it).Does this mean if this happens and my printer is not that of a pre 2013 machine, then its toast ??
