- Nov 27, 2010
- Copenhagen Denmark
- Canon MP990
@RWL There is one thing that just came to my mind, The clearance over the cartridges when installed in some MG model printers is very tight. That is the reason for the introduction of the low profile plugs and zero clearance plugs.
So I suggest to flatten that "blob" on top of the hot glue plug. There have been posts on the forum about a standard plug being pulled out from the refill hole, resulting in all ink leaked out from a cartridge. A too high plug might also cause the cartridge to jam, and maybe damage the printer mechanism.
So my recommendation is to use the "Zero clearance plugs" from Precision Colors instead of the hot melt glue plugs. Remember to secure the plug with a piece of aluminium tape.
These plugs are not easy to handle, but a wooden cocktail stick or toothpick is a good tool to handle the plugs. Make sure the tip of the stick/tooth pick is not too sharp, so you don't puncture the plugs.
You can read more about top clearance in this (lengthy) thread.
