- Apr 19, 2007
- USA
- Canon MB5120, Pencil
Yes, my post concerned refilling using the German method. I am not commenting on the traditional top hole method since I do not use it.ghwellsjr said:Startman, I think the 3/4 came from a top filler to avoid oversaturating the sponge. It doesn't apply to the German refill method.
I read the comments in the previous years about trying to keep the top part of the sponge free of ink, just the way it comes from the factory when new. My own refilling experience has proven this as unnecessary. It is true that if too much ink is in the cartridge as a whole, and especially if ink rises above the sponge in the sponged-side, then ink will leak from the ink exit port until equilibrium is achieved. But one can saturate the entire sponge with ink - no white left on the sponge - in and of itself and still not cause a leak. More than just a saturated appearing sponge needs to occur before a leak happens.
One of the rules OM2 is seeking should be to never use or store a refilled cartridge via the German method BEFORE it has proven not to leak with the second resting period. Overfilling at this point is easy to take care of since you should be using precautions against messes at this point anyway.
