Trigger 37
- Dec 23, 2006
inkoholic,.... I don't know that your problem is in uploading the Service test print.   It is just an image like the nozzle test prints you've loaded.   In looking at the pictures you did post,... the black matrix showed several flaws,...but we know from earlier scans that there was no problem.   This tells me you are not getting sufficient ink into the head.   Once you clean the head and install the head with GOOD ink you also do a cleaning cycle,..right.   This is the action that primes the head and FILLS it with ink.   If the head is full of ink and you print a nozzle test print,...the back matrix should come out perfect.  If it does not, then you didn't get the head primed.   Priming the head depends on all things working correctly.   The ink carts must be good.  The head must be clean and free of clogs, the ink pads must be clean and not filled with old dried up ink, the purge values must be clear of all old ink,..the purge tubes must be connected to the purge vacuum pump and the tubes must not be clogged up with old dried ink (just as the printhead could be), the vacuum motor inside tubes must be clean and create the correct amount of vacuum to pull ink all the way down from the ink cart, through the head, out of the nozzles, through the ink pads, through the control valve, throught the tubes, throught the vacuum pump,...and finally the ink output tubes to the bottom of the printer CAN NOT BE CLOGGED OR THE VACUUM MOTOR CAN NOT CREATE THE VACUUM.
If you continue to have problem I would get rid of the Windex for cleaning and use HOT water. If you are tired of this approach, then buy a new head and pray that this fixes your problems. If you still want to try and clean everything I mentioned above, then make a black cleaning ink cart filled with hot water and run nothing but "Black" cleaning cycles. This will not only attemp to clean the head, it will clean the ink pads, the valve, the tubes, the vacuum pump, and the exit port to the waste ink pads. Don't worry how much water you are putting in the waste pads,...It is water and will evaporate.
