rjanowsky
Germany - Northern Ruhr Area
Epson SC-P600, HP Envy 4525
10m ago i discovered that my new mac has only USB-C ports so i can't use my i1pro1 to scan the patches (argggggggg i was so excited to try chromiq and the @pharmacist ruler), i will have to wait for the USB-C->USB A female adapter and hope it will work with i1pro1 devices.
I'm using a M4 Mac mini with a i1pro1 connected to a usb-c to usb-a adapter. No problems at all. Should work for you.
mavtop
Epson XP 15000
Perfect i hope it will be here in 2 days,
for @pharmacist the gap is like on your image i can see the top/bottom spacers but no adiacent (upper/lower) row
itsab1989
Epson ET 8550, Canon Pro 300
Hi all and thanks for the hints you gave me, for now i will try with the 700 patch target (by @pharmacist) and i will compare against a 800 more patch target i created the first time with argyll cms manually.
For @itsab1989 i don't know if it is a feature, but if i reload a ti2 file to continue a project, it will reset the patches number to the default one 4xx (i don't remember the value), like if in the project specifications was not written all the information (or maybe in the load it will not read or set the values correctly), so i need to set the patch size, the colored/bw spacers and all the values that i have set when i generated the chart initially, also the chart notes are blank, while i had filled them.
Maybe i need to tell Chromiq to save the settings in some way ?
Attached is the load of a 700 chart patches with path size 8mm and 95% patch height (now defaults), with chart notes (now not present), i had removed stamp targen and layout engine (now active), paper say Portrait but it is landscape and it shows landscape, clip border was off (and it is off from preview) but say on, instrument margin are the default i had changed them, it has a fixed seed 142 and it now says random and no seed selected with number 0 (but the chart shown in preview is correct).
All the modified options for that chart layout are lost in the interface but the preview seems corrected.
Thanks for the report! I will have a look at it later :)
