- Thread starter
- #451
itsab1989
- Feb 11, 2026
- Epson ET 8550, Canon Pro 300
Thanks for your detailed report. And sorry that I did not pay more attention to this before. At this very moment an update should be on GitHub that improves on this and now you should be able to apply changes to those settings without closing and restarting the app - clicking OK in the settings should be enough.Ok i finally found the bug (unless your intent @itsab1989 was that)
all the settings in Chromiq Preferences panel that i change (for example in Chart Layout, font, size, offset and all the rest) are not applied at the chart i'm creating, i need to change the values, exit from Chromiq, relaunch it and now all the settings will be active, but if i need to change a value, i need to change it, exit Chromiq, start it again and now it works.
Hope it can help you to debug
Edit: well give it 5 minutes to finish maybe
