- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
I never gave a waste tank a second taught at any time because you can always pull the cover from the printer and wash out or replace the waste pads when that time came on any A4 Canon printer.
But all of these Pro printers are getting bigger and bigger and are not as easy to take apart because of their sheer size bulk and weight, and of course bigger means more wasted ink building up inside.
But since fitting the waste tank to my Pro 1 printer which was a bit of a disaster at the time (My fault entirely) this external ink tank has become far more than just a waste tank, its become a little gem.
This little thing (The Potty) just works so simple that I am surprised I didn't think of it before now because I suppose like most other guys I taught they were only suitable for use in Epson printers. (My ignorance)
I was reluctant to take the 9500 apart at first especially so soon after my disaster with the Pro 1 but as it was all ready dead I decided to see how easy it was to remove the top covers and fit the external waste ink tank, there were no hidden traps inside thankfully.
The waste ink tube coming from the purge unit is fairly accessible and not too difficult to reroute and drilling a very small hole in the in the front of the printer is fairly easy also,
the added bonus here is that the front panel covers up your handy work and the tubing is hidden behind it.
The Pro 10, Pro 100, Pro 9000 are all very similar if not exact to the Pro 9500 so they too can benefit from an external waste ink tank without having to do anything more that just removing the top cover..
The benefits of having an external waste ink tank fitter are:-
I am now in a position to know exactly when the printer does a head clean cycle or a good purge of the nozzles by simply monitoring this little external clear waste ink tank.
It has become another ink monitor so to speak and I can tell at a glance how much of my precious inks are been flushed down the drain to the nearest gm and more to the point how to reduce it.
I have now fitted two potty to my A3 printers and intend to fit a couple more in the coming months, high on my priority list is my iX4000 the waste is mounting up inside that and it will need some attention soon.
