Stuck starwheel on 3880 producing a cut mark on all prints
Umberto Gladys
Epson 3800
One of the starwheels on the front input tray of my 3880 is not moving as it should and as a result producing a cut mark on every print that is fed through the manual back tray. Every other starwheel functions as expected. Is there a way to simply disable this single starwheel of some way to easily fix this?
Umberto Gladys
Epson 3800
Did a Google search using "starwheel on 3880" and several results may apply to you.
https://www.google.com/search?client=firefox-b-1-d&q=starwheel+on+3880
The first result seems like an excellent guide to resolving your issue, though it might be a good idea to look at as many search results as you can as there may be something better of more to your liking.
https://jkschreiber.wordpress.com/2016/08/08/how-to-disable-star-wheels-on-an-epson-3880/
Thanks. I saw and read that WordPress link too. Just not sure I want to disable all of them just the non-functioning one and his solution is all or nothing. I tried to lubricate the one that is stuck but that didn't help either
Did you explore the other links in the Google search? Chances are good someone else with your issue wants a similar resolution as you.
I do not have an Epson 3880 so I'm flying by the seat of my pants on this. Hang in there. The Epson experts have yet to reply.
Easy fix..
Raising all of the Tractor wheels slightly on the front of the 3880 is the best way of eliminating these annoying marks for good, it won’t cause any un intended issues, try it on a few prints first, then decided if it is the answer for you.. Nothing ventured..;)
