Got hold off some interesting spongeless refillable Canon BCI3 cartridges. They are completely spongeless and can be easily changed into CIS
They look as though they come from http://www.jetyoung.com/pro-e-refill-cartridge.htm
Unlike the MIS spongeless there is no sponge at the exit port. There is a soft small silastic plunger offset in the exit port. When the cartridge is clipped in the printhead the plunger is pushed up and the ink is then allowed to flow out. Thus the exit port is self sealing when removed from the print head. There is still a clip to go over the exit port for refilling. The refilling process involves removing the black plug from the top of a cartridge. A syringe half full of ink is then pushed into the hole. The tip fits snugly into the hole. The syringe is used to suck air out of the cartridge and then released and ink will be drawn in to replace the air withdrawn. This is repeated a no of times until the cartridge is full. The hole is left unplugged as this is the breathing hole.
Here is a pic of the exit port and you can see the plunger in it. The cartridge is resting on the exit port clip
I haven't worked out the physics of this cartridge but it seems to have lots of different chambers. Along one side there is a clear membrane the covers passages and a filter screen.
As well as being a standalone refillable cartridge it can be used in a CIS. Here is the black cartridge already filled in a CIS for a Canon IP3000
I obtained this setup from www.inkbank.com.au here in Australia - great support from the bloke that runs the show.
