Recently purchased a Canon MB2720
seseeley
Do you believe these homemade refill tools pierced the silicon plug at the back of the cartridge output port? Wouldn't cause problems?
I'm fairly certain the pink homemade tool I made is too loose. It doesn't seal at all.
palombian
Belgium
PRO10,PRO9500II,MB5150,MG8250
Try to shrink some tube around it to enlarge the diameter (heat shrinkable tube is used to protect/insulate electric wires).
seseeley
Good idea thanks. I'll try this.
I use syringe needle tops which I cut down several of them and they have served me well, it fits into most cartridges, and if you’re having a problem with yours then try pushing it in a little firmer and that will hold the seal..
I got a half dozen new refilling clips from OctoInkjet and found I had to cut some of the tip off because it was to long for some cartridges, but the homemade one worked just fine..
Capture77.JPG Capture.78JPG.JPG click to enlarge..
seseeley
Thanks @The Hat . I did the same thing. However my refill tool is too loose. @palombian suggested using heat shrink tubing to enlarge my tools diameter and create a tighter the fit. I'll this next.
nobb
Sorry to bump an old thread, but wondering if you guys could comment. I followed the Octopus video method for refilling the OE PGI-1200 through the outlet port, then swapped out the ARC chip and everything seems to be working fine. Two questions:
1. In other refill videos, people plug the air vent hole above the outlet port but the Octopus video did not do this. Is this necessary and what's the purpose? I'm assuming the air vent is connected to the back side of the internal ink bag that's inside. Wouldn't plugging this hole just impede the bag from expanding/contracting?
2. What's the purpose of taping the outlet nozzle after a refill? I skipped this step and it seems to work fine.
2. What's the purpose of taping the outlet nozzle after a refill? I skipped this step and it seems to work fine. :thumbsup
There is no need to cover the vent hole, but when refilling inset the syringe into the outlet firmly and suck some air or ink out to equalise the inside pressure then push on the plunger and inject your ink.. Then withdraw the syringe slowly. Wipe up any excess ink..
