Recently purchased a Canon MB2720
seseeley
Do you believe these homemade refill tools pierced the silicon plug at the back of the cartridge output port? Wouldn't cause problems?
I'm fairly certain the pink homemade tool I made is too loose. It doesn't seal at all.
palombian
Belgium
PRO10,PRO9500II,MB5150,MG8250
Try to shrink some tube around it to enlarge the diameter (heat shrinkable tube is used to protect/insulate electric wires).
seseeley
Good idea thanks. I'll try this.
I use syringe needle tops which I cut down several of them and they have served me well, it fits into most cartridges, and if you’re having a problem with yours then try pushing it in a little firmer and that will hold the seal..
I got a half dozen new refilling clips from OctoInkjet and found I had to cut some of the tip off because it was to long for some cartridges, but the homemade one worked just fine..
Capture77.JPG Capture.78JPG.JPG click to enlarge..
seseeley
Thanks @The Hat . I did the same thing. However my refill tool is too loose. @palombian suggested using heat shrink tubing to enlarge my tools diameter and create a tighter the fit. I'll this next.
