Pro 10s banding. This only happens in muddy mid-tones, bright mixed areas are fine. I have tried head re-alignmen.
Paul Edmunds
Canon Pixma Pro 100s
- Are you running a Pro10s or 100s ?
- Please post a nozzle check print
- Which type of inks are you using - OEM Canon or refill ?
It looks like an ink delivery issue with one of your carts !
Paul Edmunds
Hi.
I am using Octoinkjet on a Pro 10s. Clear chroma problem?
Artur5
Kmt. 0.
As far as I can see that nozzle check is OK. The alternated dark patches in the chroma band are intended to look this way. No problem here
Banding in real life pictures can be software related as well. Have you tried different driver settings? -quality mode, type of paper, etc.
I’d risk giving both the Photo black and Grey carts a good flushing out with a little Fairy liquid in warm water, then rinse with clean water, and then fill and try the same photo again.. Don't forget to shake the refill bottle before refilling..
P.S. Clear Chroma is working fine and besides it can’t give you banding on your photos..
Paul Edmunds
Thank you.
I'm going to try a new Canon Photo Black & Gray and report back.
palombian
Belgium
PRO10,PRO9500II,MB5150,MG8250
I observed this now and then with Octoink GY, but not as bad as this.
Did you try both Normal or High Quality settings, the latter should be better.
Paul Edmunds
Yes I tried both quality settings, no difference.
Paul Edmunds
Update.
Still waiting for the new carts to be delivered, they have been returned to the warehouse twice! Don't you just love rural France!
