Printprism: I have bought it to test its capabilities and quality of the rgb profiles
Today I bought a license of the Printprism to generate rgb printer profiles. I have the ET-8550 printer/scanner so I will give it a try this weekend and see how the results are by comparing the profile quality side by side with my i1Pro2 and i1Profiler.
Finger crossed and hopefully it works as promised.
Epatcola
various
Hopefully you can do what the author has failed to by posting a Printprism created profile for an ET-8550 supported Epson paper. One of their glossy papers preferably.
OK, I just installed the software and unfortunately it did not install the necessary printer-target-40.tif on my system (must be bug I think). I contacted Mike Chaney in order for the file to be sent manually by mail.
OK Mike just give me the latest version and the problem is now solved. The previous version had a bug not able to find the file.
There is already a new version 1.11 available, the software does not appear to be stable yet.
I have downloaded the latest 1.11 version and the problem has been solved now. I will print a few targets with my different printers and have a side by side comparison with this new technology and the i1pro2 (using the TC9.18 target as comparison) with different paper types and ink sets.
bwrobins
Epson ET-8550, Epson ET-M2170
The more recent versions have something like 15-20% of the reported gamut volume of the OEM profiles just gone in the profiles I'm getting out of it. :confused:
Interested in the experience of others.
So I started to test now.....the first impression is the profiles are pretty good, but at the expense of a slightly smaller gamut than using the i1Profiler.
I will start with a total new generic high glossy unknown paper with I think alot of OBA's to see how Printprism will perform compared to the i1Pro2 (using the TC9.18 target):
The printer is the Epson SC-P900. The printer-target-41.tif has been printed blown up to fit the page in order to get larger patches for the software to scan.
Epatcola
various
When comparing profiles I created with an i1studio and Epson installed profiles for the ET-7750 (ET-8550 predecessor) I found the Epson profiles to be a little optimistic all round.
OK Folks,
yesterday I have done some tests, but I did make some errors: one should not use the sharpening function to print the target and also important is to trim the target with scissors in order to remove all the white paper area surrending the target to be scanned. If not this interferes with the scanning process like I have experienced and was a bit puzzled by the rather irregular 3D projection in i1Profiler gamut viewer. After correcting the modus operandi to the recommended procedure as described on the online manual of PrintPrism.
To begin with this is the gamut view of the target made with the Netbit Glossy 300 gsm paper (Aldi Belgium) which is a cheap but very good glossy paper printed on the Epson ET-8550 with 2 profiles: one made with i1Profiler generated with the TC9.18 target and one with the PrintPrism scanning method on the Epson ET-8550:
Blue: created with PrintPrism
Red: creaated with i1Profiler
I already have done alot of previous testing (with some wrong settings), but I have discovered that all the profiles I have generated with printprism for several types of paper (Netbit Glossy 300 gsm, Europrint Satin 270 gsm, Calumet Matte 230 gsm) on 2 different printers: Epson ET-8550 and the Epson P900 that the Printprism are all consequently smaller in gamut (in the greens and the reds), but the softproofing says the difference is indistinguishable:
Both profiles are generated with the neutralise grey option checked (i1Profiler: neutralise greys set at 50% and in Printprism: tonality neutral: checked).
upper softproofed image: Printprism profile, lower image: i1Profiler profile and both images are softproofed using the relative rendering intent and BPC: one as recommended by the PrintPrism software.
The first impression is that (after I have corrected my wrong printing and scanning settings) the PrintPrism software really does a good job in generating rgb printer profiles.
I will post some extra findings in the upcoming posts, I have to do some extra testing.
