Hi
@jctay ,
Thanks for your feedback and showing us your results....
I have a few comments from what I can see...
The "Contract proof check (ISO 12647-7)" and "Validation print check (ISO 12647-8)" report you posted have a red text warning:
the profile has been rebuilt since this sheet was printed, so these figures describean older profile than the one now in the run
This means you have created a new profile at some point, but did not re-create the colors of the verification chart, and then print that and then re-measure. Thus, it seems (if I interpret correctly), that the measurements you did measure are describing the old profile, not the new one. You should check what you did exactly, and preferibly re-create the verification chart in "From Profile's Gamut" mode, then print and measure again.
Then, the reports contain both "Within gamut" and "Beyond it" columns, which means that you did not use colors on your verification chart that were only within gamut, using "From Profile's Gamut" mode. (you have to remember to click on Generate Chart after clicking on "From Profile's Gamut" mode in Create Chart). Thus, you printed and measured a chart that was the original patch set you had for your 192 patch chart. The
This image you posted with the distribution of the colors for the 192 patch verification chart proves also that the patch distribution is not evenly distributed, which is how it looks like when the normal patch set is viewed through the profile. If you had used "From Profile's Gamut" mode it would be much more even. Though, for some reason, this view does not show the out-of-gamut patches.
Also, the distribution comparison image you shared, shown again below, shows a patch set of the 572 patch profiling chart that is not the best. There are no near-neutral gray rings for better neutral. I suggest you use one of the 600 patch presets supplied in ChromIQ instead, shown below:
Distribution of 600 patch preset for 10x15cm / 4x6" photo card. This is a better chart for profiling than the 572 patch chart you used.
Note also that the Evenness check matrices
- Maximum ΔE00, between two of the nine sheet areas (within gamut)
- Maximum ΔE00, one sheet area against the whole sheet
They require a minimum of 9 x 9 grid of patches on the verification chart, thus it could not be judged for the 192 patch chart you used.
If you wonder which chart can be used, among all saved presets (custom made or built-in) you can click on button "Which presets can be used for verification" under the Create Chart tab, while Run type = Verification.
Questions about the reporting feature:
What is your impression about the reports? Does it supply you with the information you need for quality assurance?
Comments? Impressions?
Cheers,
Knut
