- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
Well if you are then I would suggest you think strongly about fitting an external waste tank on it before you even start to use it.
There are two good reasons for fitting one; the first is you never have to worry about the ink absorber pads filling up on you not even once !
The other reason is you can see at a glance each time the printer does actually purge and dump ink on you, and you may be able to reduce the amount of purging it does and so cut down on the wastage.
Now you may think it doesn’t concern you but after a while using the printer you may start to wonder if it is wasting ink each time it starts to hum, purr and clatter.
But if you have a waste tank fitted you’ll know exactly whether it’s just preparing to print or is in fact dumping ink, it’s an extra ink monitor that works in your favour.
Now it’s not difficult at all to just pop the top cover on the Pro printers and once you do that you will be able to see how easy it is to fit the tubing for an external waste tank..
If you’re not going to refill it is even more essential that you watch your ink costs !
