- Apr 19, 2007
- USA
- Canon MB5120, Pencil
I am not an Epson owner, so this is the first I've heard about encrypted print heads.
After watching a different video here it seems the "first lock" was Epson's first print head firmware code to prevent use of their print head in a non-epson printer (eg a Chinese knock off). The speaker in the video does not say the lock was designed to prevent the Epson printer from using non-Epson chipped ink cartridges, something that might be built into the printer's own firmware and flashable with updates.
Back to the "first lock" story... a "decoder" was all that was needed to bypass the coding ID process. It is the "second lock", ie newer generation print heads, that seems to be problematic to bypass. The newer code is just not compatible with the "first lock" generation decoders.
According to the video I linked, the earliest generations of these Epson R2400 print heads were "unlocked" and could be used in non-Epson printers without any workaround. Also, the young man in the video uses a different numerical code on the sticker on the print head to identify first versus second lock versions. Maybe things have changed since 2016 when the video was made.
Interesting stuff.
Interesting stuff.
